Escalation rules - Add/Subtract to float field using "Action Builder"
  • September 27, 2024
  • 60 views
I just wanted to ask, if it is possible to add/subtract to a float field using the action builder on escalation rules.
If I’m using the “Reset Escalation Level” option for the “Escalation level” to cause the rule is re-run if the criteria is met, but I want to restrict the amount of re-runs of the escalation rule WITHOUT having to build an escalation rule X amount of times to check + set the field each time.
For example, A single escalation rule that adds +1 to a reminder-no field and the criteria of the same rule will only run when the reminder-no field is between 1-5 etc.
Is this possible?
raluca.zarnica
Hi Justin,
Unfortunately, the action builder does not natively support arithmetic operations directly on fields.
However, to further discuss about this as a potential new feature, please reach out to us either directly via chat, or by submitting a ticket.
