firefox oddities
  • January 22, 2024
  • 87 views
jsidoti
Guru
anyone else experiencing strange behavior using Firefox 121.0.1 (64-bit) with sysaid?
When I go to close a ticket, for example, a dialog should pop up asking if I want to add it to the knowledge base
In my case, it’s putting that dialog into a new tab instead
jsidoti
Guru
  • Guru
  • January 22, 2024
found it… it’s ublock origin
make sure you add your helpdesk url to the safe list or disable it for the sysaid session
  • January 22, 2024
Hello Jidoti,
We suggest that every ad-block or any similar extensions should be disable for Sysaid since it affects some of the capabilities such as pop-ups.
Great finding and thank you for sharing that with others.
jsidoti
Guru
  • Guru
  • January 22, 2024
firefox added ublock in their latest release.. I honestly never used it before
and I usually add my sysaid to the trusted zone anyway
