Answer
Importing Categories
  • March 13, 2025
  • 5 replies
  • 82 views
I’ve been tasked with bulk importing some new categories into SysAid and was wondering if its possible to set the EUP groups as part of the import? I suspect its not possible, but figured no harm in asking!
Service Desk > Import Categories
Best answer by gabriel.lupu
Hi ​@rdtjbrown
Unfortuantely, that option cannot be added within the CSV file since that field is not available within the import categories option.
Please let me know if you have further questions and also please note that you can contact us at helpdesk@sysaid.com for opening a ticket with us.
Have a great rest of the week!
gabriel.lupu
  • March 13, 2025
Hi ​@rdtjbrown
Thank you for contacting us!
Yes, you can set if the categories should be visible within the Self Service Portal, please make sure that you have a dedicated column within the .CSV file with the answer Yes/No, depending on your needs.
In case you have any questions, please do not hesitate to contact us by sending an email to helpdesk@sysaid.com
  • March 17, 2025
Hi ​@rdtjbrown
Hi Gabriel,
Setting whether or not the category is visible is a simple yes/no. What I’m asking about is setting the actual EUP Groups, which would be the Group Names, comma separated, That way, If I need to import 100+ categories I don’t have to go into each of them as set which groups can see the category.
  • March 18, 2025
Specifically this field:
gabriel.lupu
  • March 18, 2025
Hi ​@rdtjbrown
  • April 4, 2025
Thanks for confirming Gabriel. I’ll just have to manually tick each one.
