I want to create new incident templates, but nothing is showing in the menu:
The view to filter the already created templates was changed:
After changing that parameter is when the problem started to happen. As I previously mentioned, to set back the previous configuration is not possible as there is any button or function to select.
I would appreciate if some​one knows how to resolve this issue.
Thanks in advance!
Best Regards​​​​​​
Hello @Support_KB
Thank you for contacting us,
Please contact us via our email address helpdesk@sysaid.com in order for us to create a Service Record and address to this.
Thank you in advance!
