Incident to change management
  • May 6, 2020
  • 6 replies
  • 71 views
What is the best way of getting an incident to change management? We have several tickets that come in that require the approval change management. These are routine requests but still need to be logged in our change management system.
DenaWF
  • Collaborator
  • May 12, 2020
Hi chalupabatman, The only thing you can do is - in the incident, link it to the change. See attached screenshots. Then you can create a new change. And your incident will be linked to that change. Hope this helps. Cheers, Dena
  • May 13, 2020
That is super helpful! Thank you! Now is there a way to have linked tickets update down. IE if we create a change management ticket from that incident when we preform the change it updates the incident?
DenaWF
  • Collaborator
  • May 13, 2020
chalupabatman
The only place it updates once they are linked is the solution field. So when the solution field in the change is updated, it updates the solution field in the incident.
  • May 13, 2020
So fields across tickets can be linked, is there a way to for us to link more specific fields?
DenaWF
  • Collaborator
  • May 13, 2020
chalupabatman
Hey chaupabatman, Best to have a chat with your client success manager as this is not something out-the-box. It would need custom development and our developers would need to scope and understand exactly your needs to make sure it can be done the way you need it. Cheers, Dena
abagugu
  • March 24, 2021
xasxax
