Incoming email - Generate a request instead of an incident
  • March 15, 2013
  • 10 replies
  • 97 views
We'd like to automatically generate a Request based on an email account instead of an incident. A) Is this possible? 2) ITIL is responsible for all of society's ills.
MichaelZ
  • March 18, 2013
I've been thinking about this as well. We should definately have the option to set up rules for incomming emails. The standard route could be email -> Service Request and mails from our monitoring systems where the subject is known based on the event type could be routed into event or incident management.
  • March 18, 2013
Maybe this feature request is what you're looking for? /Sysforums/posts/list/279.page We haven't seen it yet but Oded and David talk about it.
  • March 18, 2013
I'd just like the option of selecting an Incident or a Request.
5.7FSN
  • March 19, 2013
You could accomplish the incident or request by having two emails, and then setting the one with the requests to run an escalation rule every 5 minutes to move those incidents to a request. Quite the undertaking/workaround, but that's one way
  • March 19, 2013
I tried setting up an escalation rule, but it doesn't appear to be working. The only place you can deal with Service Record Type is in the action builder where I set it to change to Request. Is there another step I'm missing?
5.7FSN
  • March 20, 2013
Yeah you have to do it in the action builder. Have screenshots of your ER rule?
  • March 20, 2013
Here is the screenshot in two halves
5.7FSN
  • March 26, 2013
Everything looks correct. Only thing is I normally change that time out to every 5 minutes since that's when the system interval is. I've found in the past that ER's don't run sometimes if that value is set to less than 5 min. Did you test this during operating times as well?
  • July 14, 2021
This Post is from 2013 but I am experiencing the issue right now. Does anyone have a solution? Email routing is set to create a "Request" but instead showing up as a "Incident" no matter what I try. Any help would be appreciated.
Super SysMate
Forum|alt.badge.img+3
  • Super SysMate
  • July 18, 2021
Richard B
Good Morning Richard B, the possibility of doing this is controlled by the e-mail rules. However, it is essential to observe the forwarding rules. Most of the time, the forwarding and the email roles are in conflict. Please check. best Karlson
