Life just got easier with Merge Tickets
  • March 1, 2018
  • 9 replies
  • 456 views
Oded  M
Don’t you just hate when your support queue has multiple tickets about the exact same issue? Ok, so the Marketing printer is jammed. You got it. There’s no need to have 100 different tickets about it. It’s not like that’s going to help you solve the issue any faster…. Right? Well...that’s all about to change with Merge Tickets Find out how to keep your ticket queue clean by merging overlapping tickets. You can view a short video documenting the Merge process on the Cloud Latest Release page (https://www.sysaid.com/product/cloud/latest-release). * This feature will be available in the next on premise release - beta scheduled for April
MatthiasManzone
hi all, I've tried to enable the merge function for my user. As a SysAid master administrator, I can access the [merge] function after I've selected 2 SR in the list. But my users can't, even though they have been given the permission using Group permissions. I even tried to merge only incident from the same company + same category + same admin group... no luck Any other setting I need to enable? Am I missing anything obvious? User permissions SR list Using cloud ITSM v18.2.12 b2 Thanks
MatthiasManzone
Thanks Ricky from support for fixing the issue. If anyone is having the same problem, the "Only SysAid Administrators can update SR fields from list actions" checkbox under [Settings > Service desk > General] must be unticked. Otherwise only SysAid System admin have access. Problem solved Cheers
I'm not sure I understand that logic. Oded, why have a feature that is granted via permission on a Technician's account that can then be taken away via an application setting?
  • February 13, 2019
I had the same issue thanks for the post, still a little confused also paul
brberglund
  • March 20, 2019
I really don't understand the benefit of this feature...
  • September 24, 2019
What about archived tickets? I have found that the merge feature will still update them...
5.7FSN
  • October 18, 2019
I wish it would purge the merged record, or perhaps put it in status that could purge after sometime once merged. I don't need the old record once everything is merged..
brberglund
  • December 2, 2019
5.7FSN
This is the EXACT reason that I don't understand the benefit of this feature!
  • June 25, 2020
We love merge tickets!! One question though. When we merge tickets, the tickets that get 'merged closed' reopen when the main ticket is updated. It is really annoying where there are lots of merged tickets. Is there anyway of stopping it?
