Matrix not showing anything after upgrade to 20.4.74
  • April 22, 2021
  • 44 views
We use the Matrix a lot,but after the update the view is just blank. If I try to swap the headlines around we can see the data. Our original matrix view is like this. ]https://ibb.co/7kQpm2h after changing the horizontal and vertical sections (with a lot of - you cannot do that...) we get this. https://ibb.co/S0dG19X Anyone else having issues with the Matrix view after the latest onpremise update?
Yes, we have seen issues with various fields on the vertical and horizontal axis since at least last fall. I was told Bug# 57157 was the culprit for our situation.
  • April 27, 2021
Just got answer from SysAid support and they told be it looks like another reported bug : 60814. Looks like we have to wait again..
