Merge duplicated Asset Records
  • June 10, 2022
  • 0 replies
  • 78 views
From time to time, asset records will be duplicated because for whatever reason (client reinstalls, client corrupts, etc) a duplicate record appears. This is disruptive as having a duplicated record means that the history for that asset gets split across two records, and it takes time to manually merge the records back. I would like to request a feature that like with ConnectWise, when you delete an inventory object, that it asks you if you would like to copy all records attached to that asset record to another asset record, or have the functionality to click a button to do the same thing (copy all associated records over to the new asset record. This would save a lot of time and headache.
