Notifications HTML
  • March 4, 2019
  • 73 views
Hello everyone! I need your help. I'm creating a workflow for a request and sending custom email with alert. Editing the "Workflow Notifications" under the menu "Service Desk Templates" the system recognize HTML in the right way. The problem is when i try to edit " Notifications" under the menu "Customize". I paste the same code used in the Workflow notifications, but when i recieve the mail, all the "<" of the html's tags are repalced with a "{". Has anyone ever encountered the same problem? Has everyone a solution? Thanks
https://community.teamviewer.com/t5/TeamViewer-General/Device-Access/m-p/55824/highlight/false#M26708
  • July 16, 2020
i'm having the same problem for my admin notifications after upgrading to v20.2.14 b4 did you ever get a resolution to this?
alefabian
  • July 20, 2020
Unflag "Modify the "<" character to secure against cross-site scripting" setting under Settings > Customize > Appearance
