On the Incident/Request form, how can I align fields next to each other?
  • March 15, 2023
  • 92 views
zoewalters
I find that adding fields when designing my incident or request template makes the template longer.
I’d like to have the Impact and Urgency fields next to each other in the body of ‘general details’ tab, not on top of each other.
Is this possible? It means there is a lot of wasted space in the template!
Thanks.
Best answer by jsidoti
zoewalters
that came up recently.. and basically the answer is not yet
jsidoti
Guru
  • Guru
  • March 15, 2023
zoewalters
