Reusing SR Custom Lists - Chaning/Deleting Values
  • July 30, 2020
  • 0 replies
  • 70 views
Reusing SR Custom Lists We have a Service Request Custom List (cust_list2) that I would like to re-use. I'm not fussed on the data associated with this field in previous SR's. However for me to remove options associated with this field previously I get an error. The selected value(s) ('value') is being used in one or more Service Records. To delete this value, you should update the relevant Service Records first. I have tried via sysaid to change this on multiple SR's but it does not seem to work. So I went to the database and change them directly, easy done, but this is not reflected on the SR in Sysaid. I am changing 'dbo.service_req.cust_list2' is there somewhere else this is set per SR? Any assistance would be appreciated.
