Sending message fails randomly
  • October 18, 2021
  • 76 views
The past weeks we started seing a message will fail randomly with this error. Your message failed: Could not convert socket to TLS OK We are using office365 as mail provider. Any ideas where to start looking.?
alefabian
  • October 20, 2021
Hi JSH, your SysAid is likely not updated to a release supporting TLS 1.2 - previous versions of TLS are no longer supported by Microsoft. Upgrade your SysAid and change the TLS version of your email integration.
  • October 20, 2021
Right, we are running v20.4.74 b10. But it occurs randomly - so a bit strange if it should be that. Will try to upgrade and hopefully it will also fix some other formatting problems we have had since 2 upgrade ago..
