Survey response
  • August 21, 2024
  • 103 views
Can I remove a survey response from a report?  One of our support colleagues input a test response and they wanted to see where it was recorded.  It is now appearing on the ‘Satisfaction Level by Administrator’ report and I’d like to remove it before I distribute a copy of this report to the rest of the team.
Many thanks.
**AI magic at your service!**
To remove a survey response from a report in SysAid, follow these steps:
1. **Log in to your SysAid Administrator account.**
2. **Navigate to the 'Analytics' or 'Reports' section** of the SysAid dashboard.
3. **Locate the survey or feedback module** within this section.
4. **Select the specific survey** for which you want to delete responses.
5. **Open the survey results or reports** to view the collected responses.
6. **Identify the test response** you wish to delete.
7. **Use the delete option** provided within the survey results interface to remove the selected response.
If you encounter any issues or need further assistance, please refer to the SysAid documentation or contact SysAid support for help.
AlexanderChr
Hi @SuperSalmon ,
If you'd like, we can remove the survey directly from the database.
You can either open a service request via email or send me a private message with your email address, and I'll raise the ticket on your behalf.
Looking forward to your response.
