Answer
Timer - Still accumulating
  • November 8, 2024
  • 81 views
I’ve run into a bit of a head scratcher. The “Time to Repair” timer is still accumulating on a “Incident” service record that is in the “Waiting for Customer” status but I think I’m going blind. Is there something wrong with the below logic?
(Service Record Type = Incident And (Status <> Closed Or Status <> Rejected Or Status <> Customer Test Or Status <> Waiting for Customer Or Status <> Workaround Or Status <> On Hold Or Status <> Resolved Or Category <> Releases))
Timer screenshot
Best answer by rdtjbrown
Solved, changed the OR statements to ANDs.
  • November 8, 2024
Update:
Just modified the expression slightly, but its still going up:
(Service Record Type = Incident And Category <> Releases And (Status <> Closed Or Status <> Rejected Or Status <> Customer Test Or Status <> Waiting for Customer Or Status <> Workaround Or Status <> On Hold Or Status <> Resolved))
  • November 8, 2024
