Tooltips
  • June 17, 2021
  • 27 views
poomonster
Hi Is there any way we can chage the tooltip text (the little pop-up when you hover over something) so that it can say a bit more to help our end users fill things in. A lot of the time they leave fields blank because they don't know what to put, which wastes a lot of time for us having to chase them to get the info. If we could put a better description or short example it would help. Thanks Lee
  • June 30, 2021
We have used two options, edit the Display name of the field or add another text field with instructions for the field below and Hide the Label.
