Use of "cc" field in incidents
  • July 3, 2023
  • 115 views
Forum|alt.badge.img+2
I support users who work shifts and need an easy way for them to communicate with their colleagues on the opposite shift to them. If I use the “cc” field in the incident form, does the cc’d user get copied in on all email notifications on the incident?
Best answer by alin.lupascu
@JRichardson Yes, the CC field is meant to have the user/s copied in all the notifications re the specific SR.
You might also want to consider “Instant Message” if you want to send a heads-up to another admin.
You can select the “Instant Message” from the send message.
The message will be displayed as an “alert” on the bell once you log in.
alin.lupascu
  • July 4, 2023
