verification field
  • August 27, 2021
  • 25 views
If there a way to put a "verification" field in to a form and have a check to make sure the info in both match? Example enter name: and then confirm name: I'm sure the technician can confirm that they match after the form is submitted, but I was wondering if there is a better way to do this. Thanks, Chris
alefabian
  • August 31, 2021
You can create a new custom field and develop a Display in Form trigger to check the matching. If you are not familiar with javascript or you are using a Cloud version, contact your Account Manager.
  • August 31, 2021
I am not familiar with javascript and we do not use the cloud version. Ours is on premise.
alefabian
  • August 31, 2021
Submit your request - https://helpdesk.sysaid.com/ - and the Professional Services Team will help you to develop the trigger you need 👍
