What permissions are needed to edit Incident Templates and AutoTexts(Aside from full admin rights)
  • December 19, 2023
  • 77 views
Basically title, looking to allow techs to set up some templates, but don’t want to give full keys to the kingdom. Is there any other way?
raluca.zarnica
Hi June,
You can make the admin a super admin, and use the “Restrict Access for” field from the Permission tab of the admin to restrict any sections from your environment for that particular admin, while keeping their access to the Settings menu.
  • December 19, 2023
Alright. Is there a fast way to disallow all other roles for that admin, or is it a one by one type deal?
raluca.zarnica
Are you referring to the options listed in the Restrict access field? There’s an option at the bottom called “Select/Deselect all”. You can use it, depending on the number of restrictions you want to apply.
If you’re referring to the overall permissions from the respective tab, those will have to be unchecked one by one.
Let me know if you have further questions :)
