64 Bit Installer
  • November 7, 2022
  • 370 views
Hi
Can you please provide me with a link to obtain a full install of the 64 bit version. We currently have a 32 bit version, but the server it is on is failing and we would like yo take the opportunity to upgrade to the 64 bit version.
Brad
Best answer by Erik Snider
Hi @BradG ,
Can you tell us what exact version you are using? You can find this information under the “About” in your personal menu. It’s important to know which version in order to avoid any corruption of data when you reinstall.
BE SURE to make a full backup of the SysAid server folder and DB before starting this process.
Here are a list of full installers, starting with the most recent version, going all the way to 20.1.14. Depending on your current version, you should download the appropriate installer.
Full SysAidServer installations:
v22.1.65: https://cdn3.sysaid.com/OnPremInstall/22.1.65/SysAidServer64.exe
v21.4.45: https://cdn3.sysaid.com/OnPremInstall/21.4.45/SysAidServer64.exe
v21.2.35: https://cdn3.sysaid.com/OnPremInstall/21.2.35/SysAidServer64.exe
v20.4.74: https://cdn3.sysaid.com/OnPremInstall/20.4.74/SysAidServer64_20_4_74_rc.exe
v20.3.64: https://cdn3.sysaid.com/SysAidServer64_20_3_64.exe
v20.2.15: https://cdn3.sysaid.com/OnPremInstall/20.2.15/SysAidServer64.exe
v20.1.14: https://cdn3.sysaid.com/SysAidServer64_20_1_14_b6.exe
Here additional, important instructions how to reinstall from 32 to 64 bit.
https://documentation.sysaid.com/docs/migrate-sysaid-from-a-32-bit-to-64-bit-installation-windows?highlight=32%20bit
You can then upgrade.
If you have any questions or issues, we strongly recommend that you reach out to our Support Team. Here’s the link to their chat.
Best wishes,
Erik
Erik Snider
  • November 9, 2022
Hi @BradG ,
Best wishes,
Erik
  • November 9, 2022
Thanks Eric, here is a screenshot of the ABOUT details
Erik Snider
  • November 10, 2022
Hi @BradG,
Thanks for sharing the details. So you should follow our guide and use the 20.3.64 installer for full installation. Again, if you have any issues, our Support team is more than happy to help.
Erik
  • November 11, 2022
Thanks Eric.
Finally managed to get it all sorted😵.
