Download files for upgrade to 22.1
  • October 30, 2023
  • 370 views
Can you tell me where I can download the files for upgrade my SysAid on prem.
Regards.
Best answer by iulian.olaru
Here you can find the direct SysAidServer Upgrade Patches Links (64-bit):
v23.3.34:
https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/23.3.34/SysAidServerPatch64.exe
v23.2.14
https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/23.2.14/SysAidServerPatch64.exe
v22.4.45
https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/22.4.45/SysAidServerPatch64.exe
v22.3.35
https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/22.3.35/SysAidServerPatch64.exe
V22.1.65:
https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/22.1.65/SysAidServerPatch64.exe
v21.4.45:
https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/21.4.45/SysAidServerPatch64_21_4_45_production.exe
v21.2.35:
https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/21.2.35/SysAidServerPatch64.exe
v20.4.74:
https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/20.4.74/SysAidServerPatch64.exe
v20.3.64:
https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/20.3.64/SysAidServerPatch64.exe
v20.2.14:
https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/20.2.14/SysAidServerPatch64.exe
v20.1.14:
https://dp3qdkv6ibrud.cloudfront.net/OnPremUpgrade/20.1.14/SysAidServerPatch64_20_1_14.exe
Here are the Upgrade Release Versions and Compatible Versions. Use this to determine your upgrade path. Important: Make sure you backup your database before initiating a version upgrade.
Release Date Compatible Versions
SysAid 23.3 September 28, 2023 22.4 and above*
SysAid 23.2 July 3, 2023 22.3 and above*
SysAid 22.4 February 7, 2023 22.1 and above*
SysAid 22.3 December 7, 2022 21.4 and above*
SysAid 22.1 June 6, 2022 21.2 and above*
SysAid 21.4 January 31, 2022 20.4 and above*
SysAid 21.2 September 8, 2021 20.3 and above*
SysAid 20.4 March 8, 2021 20.2 and above*
SysAid 20.3 November 12, 2020 20.1 and above*
SysAid 20.2 June 28, 2020 19.4 and above*
SysAid 20.1 February 24, 2020 18.1 and above*
iulian.olaru
  • October 30, 2023
v23.3.34:
v23.2.14
v22.4.45
v22.3.35
V22.1.65:
v21.4.45:
v21.2.35:
v20.4.74:
v20.3.64:
v20.2.14:
v20.1.14:
  • October 31, 2023
Excelent. Thank you very much iulian olaru
