How do I get a hold of v21.2
  • July 21, 2022
  • 87 views
I am currently on V20.2 and need to upgrade to the latest version. But to do so, we are told to upgrade to 21.2 first then upgrade to the latest version from there. But I cannot seem to find a page that has all the previous versions to download.
Hi @will.reid
All downloads links for relevant versions can be found here:
https://helpdesk.sysaid.com/FAQTree.jsp?id=858
*Requires login to our Customer Portal (SSP)
**Login is the same as the one you set up for our community :)
Hi @will.reid
