How to deploy Agent using Microsoft InTune for MDM devices?
  • May 26, 2021
  • 5 replies
  • 850 views
BobbyR
At our site, we have student laptops that are managed remotely using Microsoft InTune. I have the ability to deploy an EXE or MSI program from within the Intune portal. I would like to deploy the SysAid agent MSI this way, is there a way to do this? There is an option for "command-line arguments" from within InTune, does anyone know the command-line switches to use for (Account, SysAid URL, Serial Number, RDS Name, RDS URL)?
alefabian
  • May 28, 2021
You can find the instructions about how to deploy the agent with a MSI file here: https://www.sysaid.com/support/msi
BobbyR
  • June 23, 2021
I have successfully pushed the SysAid agent using Microsoft inTune, using the instructions you suggested.
  • January 16, 2023
I tried to follow the instructions and don’t know what needs to be done with the transforms file
  • August 10, 2023
@LeeRLSD please, check the documentation here: https://documentation.sysaid.com/docs/agent-deployment-guide?highlight=MSI%20Deployment%20Package%20Using%20Group%20Policy
I hope this step by step guide will answer all of your questions.
  • May 21, 2025
do you have a screenshot of your command line arguments used in Intune? i’m looking to do the same.
cheers
