Modify agent
  • January 27, 2023
  • 180 views
jsidoti
Guru
We switched from LDAP to Azure auth for our users so now the password reset services screen is no longer working.
How do I remove that from the windows 10 login screen?
Install method:
SysAidAgent.exe /VERYSILENT /URL https://www.web.site /account AccountName /serial SerialNumber /install once /AllowRemoteControl Y /SubmitSRShortcut "Help Desk" /Interval 30 /ConfirmRC Y /RandomMachineID N /AllowSubmitSR Y /LogLevel 3 /ENABLESYSAIDPS Y
is it as simple as switching /ENABLESYSAIDPS Y to /ENABLESYSAIDPS N
Best answer by jsidoti
According to tech support
Yes, if you want to remove the Password Services feature from the agent installer set the option /ENABLESYSAIDPS to N.
In case this does not remove the Password Services feature at the logon screen, you can manually remove it.
1. Go to : C:\Windows\System32.
2. Delete the SysAidUnlckRstPasswd_08501.dll file
jsidoti
Guru
  • Guru
  • January 30, 2023
Love it @jsidoti when you find the answer and share with us! Thank you for being a great SysMate!
