Renew SSL Cert
  • September 15, 2022
  • 779 views
Could you please provide steps how to renew our current SSL certificate in SysAid Tomcat? Thanks a lot
@dave.fremeth double-checked with my awesome customer care team see here guide for
SSL Configuration for SysAid In-House Edition
Hi @dave.fremeth
I assume you are working with our On-Prem version? What version are you on?
In general, the Tomcat version is updated as part of the SysAid upgrade when needed. Not sure when it was implemented but if you are on old version, highly recommend you upgrade asap.
For more info about OP current version check here.
Let me know if this helped,
Best,
  • April 27, 2023
Hi, I’ve updated the path with the new cert name restart the sysaid server service and it still shows the old cert.
What else should I do?
Ofir
Forum|alt.badge.img+2
  • June 7, 2023
Hi @OfirMY
Please contact our support team who will be happy to help: https://www.sysaid.com/support
If you need anything else, don’t hesitate to reach out again :)
