How to add a shared mailbox to Outlook
  • October 20, 2020
  • 0 replies
  • 82 views
UWLIT
Community Enthusiast
Question:
How do i add a shared mailbox to Outlook
Answer:
Add a shared mailbox to Outlook
After your admin has added you as a member of a shared mailbox, close and then restart Outlook. The shared mailbox should automatically display in your Folder pane in Outlook.
Shared mailbox displays in Folder List in Outlook
What if it didn't work?
  • If your admin only recently added you to a shared mailbox, it may take a few minutes before the shared mailbox appears. Wait a bit and then close and restart Outlook again.
  • If that didn't work, then manually add the shared mailbox to Outlook:
    1. Open Outlook.
    2. Choose the File tab in the ribbon.
    3. Choose Account Settings, then select Account Settings from the menu.
    4. Select the Email tab.
    5. Make sure the correct account is highlighted, then choose Change.
    6. Choose More Settings > Advanced > Add.
    7. Type the shared email address, such as info@contoso.com.
    8. Choose OK > OK.
    9. Choose Next Finish > Close.
