Use a shared mailbox on a mobile device (phone or tablet)
  • 20 October 2020
  • 0 replies
  • 16 views
Question:
How to Use a shared mailbox on a mobile device (phone or tablet)
Answer:
To access a shared mailbox on a mobile device, use the following steps.
  1. Sign in to your primary account in Outlook for iOS or Android.
  2. Tap the Add Account button in the left navigation pane, then tap Add a Shared Mailbox
    Add a shared mailbox to Outlook Mobile.
  3. If you have multiple accounts in Outlook Mobile, select the account that has permissions to access the shared mailbox.
    Select the account that has permissions to your shared mailbox.
After the account setup process completes, the shared mailbox will display in your account list in Outlook for iOS or Outlook for Android.
To remove a shared mailbox, go to Settings Accounts. Then tap on the shared mailbox and select Delete Account
Be the first to reply!
