Happy Summer, SysAid fans!
On-Premise v.23.2.14 is here and ready for you!
Read all about it on our Documentation!
⚡️Here are the main highlights of this launch: ⚡️
  • SysAid Windows Agent now supports Windows 11 assets
  • SysAid Agent Settings Automatic Updates now applicable to MAC and Linux assets using RDS Server’s new Configuration tab
  • New “Default Location/Department/Company” Column on the Asset Types page allows Default Value assignment per Asset Type
    • “Same as owner”
    • “Set manually”
    • “None”
  • Service Catalog Widget screen size auto-adjusts per number of catalog items.
  • New OOTB Online Users History Report
  • “Appearance” Setting now applicable to “Relational List display” Field
  • Multiple new Report functionalities
  • Improved File Import capabilities for Azure Integration
  • Optimized user experience for Service Catalog Widget
You can upgrade your version to 23.2.14 by following this link.
Hello SysAid Team,
the download link only contains version 22.4.45 and not version 23.2.14
cheers
@Karlson We’re working on fixing this, meanwhile can you please use https://helpdesk.sysaid.com/CustomPage.jsp?pageName=download_05.html&fileName=OnPremUpgrade/23.2.14/SysAidServerPatch64.exe
Thank you @Karlson for the heads up and @alin.lupascu for the link!
We updated the links in the docs 👌
Thank you for the quick support.
Have a nice day
Greetings
