iReport not opening? Java 8 may be the issue
  • August 18, 2015
  • 7 replies
  • 4748 views
Cael
  • 53 replies
Hi All, I ran in to this problem some time ago whereby for no apparent reason, when I ran iReport the splash screen would appear, but no loading took place, the usual progress bar made no progress. I have since had a few support calls about this same issue, so I figure I will post the solution here. The culprit is Java 8 as iReport is not compatible with Java 8 run time - well at least version 3.7.6 is not. To resolve this issue, simply install the Java 7 JDK (unless already installed) on the machine on which iReport is installed and then configure iReport to use the JDK rather than your local JRE. 2 easy steps: ----------------------- 1. Download and install JDK7 (http://www.oracle.com/technetwork/java/javase/downloads/jdk7-downloads-1880260.html) 2. Modify the iReport config file 'ireport.conf' found in the 'etc' folder in the iReport installation directory. (on a Windows instance; possibly: C:\Program Files\iReport-3.7.6\etc\) Open the file in Notepad or equivalent plain text editor and find the line: #jdkhome="/path/to/jdk" Add a new line below it and replicate the property name (without the hash/"#") with the correct path to your new JDK install, Eg: jdkhome="C:\Program Files\Java\jdk1.7.0_60" *File paths are not necessarily correct for your system they are just for examples and are based on a Windows environment, please double check your install paths. ------------------- Here is an unmodified ireport.conf for a 3.7.6 install in case anything goes wrong. # ${HOME} will be replaced by user home directory according to platform default_userdir="${HOME}/.${APPNAME}/3.7.6" default_mac_userdir="${HOME}/Library/Application Support/${APPNAME}/3.7.6" # options used by the launcher by default, can be overridden by explicit # command line switches default_options="--branding ireport -J-Xms256m -J-Xmx512m -J-Dorg.netbeans.ProxyClassLoader.level=1000" # for development purposes you may wish to append: -J-Dnetbeans.logger.console=true -J-ea # default location of JDK/JRE, can be overridden by using --jdkhome <dir> switch #jdkhome="/path/to/jdk" # clusters' paths separated by path.separator (semicolon on Windows, colon on Unices) #extra_clusters=
Danny Tashiev
  • 4230 replies
  • August 30, 2015
Great guide, Cael! Thanks a lot for sharing it here :) Cheers, Danny
  • April 1, 2016
This solution worked for me. Running on Windows 7 64 bit Dell.
  • June 18, 2017
Thank you so much for sharing the information. It has solved my problem
Pee-Jay
  • January 23, 2018
Hi...I am happy that the article worked for some of your guys...however as for me I am not sure I am following. I could not find the ireport.config even after searching for it in my entire Computer. I am running ireport directly from netbeans as it was installed through the ireport (1383067774_iReport-5.5.0-plugin) and I would like to be assisted on how I can configure my ireport in order for my reports to run from a jar file in a PC (windows machine) that does not have a Jasper Report Designer tool installed in it. Again, you can also assist me on what the requirements are for me to run the reports from a jar are. Thanks in advance
  • February 20, 2018
Thank you so much for sharing the information. I had the same issue under OSX and It has solved my problem !!!
  • September 6, 2020
Hi, Even I am using iReport 3.7.0 and JDK 1.8. However I am able to create reports and execute them without any issues. To change the JDK version in iReport we need to open X:\iReport-3.7.0\etc\ireport.conf and change the === jdkhome="C:\Program Files\Java\jdk1.8.0_191"==== It is worked fine for me.
  • September 6, 2020
