KB Article Report
  • August 23, 2021
  • 58 views
I would like to be able to create a report that shows how many views each KB article has. Is there an easy way to do this?
Super SysMate
Forum|alt.badge.img+3
  • Super SysMate
  • August 24, 2021
Hi AnnHood no, you cannot create a report! But in the KB you can filter in the field "All articles by" for "most frequently displayed"! The item with the highest value is also displayed as the top and the item with the lowest value is displayed as the bottom. Maybe that will help you. cheers Karlson
AnnHood
  • August 25, 2021
Bummer, thank you for your help!
