Report on CLASS
  • March 1, 2021
  • 18 views
Schluchtmann
Community Enthusiast
Hello All... I try to customize an report a way, that it shows class in the output. So not all statuses but just Active or Closed. Any idea?? Best regards Michael
  • April 7, 2022
Don't know if you ever got this figured out, but figured I would post for the next person to come along. In Reports, on the Filter Tab, "Active" is one of the options you can select. If you want to see open ticket Status is Active If you want to only see the closed class tickets use Status is not Active May or may not work depending if you have Custom Statuses configured
