Multi-Tenancy
  • June 17, 2025
  • 52 views
I would like to make better use of the SysAid tool we currently have implemented. I’ve been with the company for a short time, and I’ve identified that the tool is not properly configured. The most relevant observations so far are the following:
  • There are several entities sharing the same service catalog.
  • All users access the same self-service portal to create tickets, regardless of the entity they belong to.
There are multiple opportunities for improvement, but we haven’t made much progress due to a lack of technical knowledge on proper configuration. The available documentation online is quite limited, so I will try to make as much progress as possible using the current manuals.
In the short term, these are the most urgent points I would like to work on:
  1. Create separate companies and entities.
    (Objective: allow the creation of independent service catalogs and establish specific rules per entity or company.)
  2. Create customized service catalogs for each entity.
  3. Configure separate self-service portal entries for each entity.
## Goal
Isolate each entity so that:
* Every company has its own service catalog (categories, items, workflows).
* End users see only the catalog and branding that belong to their company.
* Administrators can set company-specific rules, SLAs and reports, while keeping one central SysAid backend.
Below is a practical, step-by-step configuration plan you can follow immediately.
## 1. Prepare a Simple Matrix before You Touch SysAid
Create a table (Excel/Sheets) with four columns: Company / User list / Admins / Catalog items.
Fill it in with the information you already have. This will save time during the wizard-type screens in SysAid.
## 2. Create Separate “Companies” in SysAid
1. Log in as SysAid Administrator.
2. Navigate to **Tools ➜ User Management ➜ Companies**.
3. Click **Add** and fill in the name, address (optional) and a short code (used later for URL parameters).
4. Repeat for every entity.
5. (Optional) Upload a logo per company here if you plan to display it on the portal banner.
Result: SysAid now has airtight containers that you can use for scoping almost every object—users, SR templates, service items, messages, themes.
## 3. Assign Users to Their Companies
1. Go to **Tools ➜ User Management ➜ End Users** (and **Admins**).
2. Multi-select the relevant users ➜ **Actions ➜ Set Company** ➜ choose the correct company.
• If you rely on Azure AD / LDAP sync, place each user in an OU or security group that maps to the right SysAid company; then activate “Assign company by LDAP branch/group” in the integration settings.
3. Test with a dummy account for each company to verify it is really attached.
## 4. Split the Service Catalog
### 4.1 Service Categories
1. **Settings ➜ Service Desk ➜ Categories**
2. For every existing category decide: global or company-specific.
3. To restrict visibility, open the category ➜ **Company** drop-down ➜ pick the company.
### 4.2 Service Items (Service Catalog)
1. **Settings ➜ Self-Service Portal ➜ Catalog Items**.
2. Add a new item or edit an existing one.
3. Under **Visibility**, choose **Specific Companies** and check the relevant company (or leave blank for global).
4. Attach any company-specific SR template or workflow.
Result: When an end user from Company A logs in, only items mapped to Company A (plus any global items) appear.
## 5. Configure Themes and Branding per Company
1. **Settings ➜ Self-Service Portal ➜ Themes** ➜ **Add Theme**.
2. Adjust colors, banner, favicon, CSS ▸ **Save**.
3. Back in the theme list, click **Set Companies** and tie that theme to the company.
4. Repeat for each entity.
• If nothing is set, the global default is displayed.
• Banners can also be company-specific: **Self-Service Portal ➜ Customize Banners**.
## 6. Provide Different “Entrances” to the Same Portal
Remember: SysAid officially supports *one* Self-Service Portal URL, but you have three useful tricks:
| Method | What to do | User experience |
| Theme auto-switch (no extra URL) | Steps in section 5 | User logs in → sees correct branding automatically |
| Company ID parameter | Email users a link such as `https://YourDomain.sysaidit.com/Login.jsp?companyId=ACME` | Sets the theme *and* filters catalog even before login |
| Sub-domain or CNAME | Create `it.acme.com` and `it.bravo.com` that both point to your SysAid URL | Keeps marketing happy; still one backend |
## 7. Entity-Specific Rules (Routing, SLAs, Automations)
1. **Settings ➜ Service Desk ➜ Routing Rules** – add condition *Company = X* then assign to the right admin group.
2. **Settings ➜ Service Desk ➜ SLA/SLM** – create a policy, select *Company* in the **Filter** field.
3. **Settings ➜ Automations ➜ Escalation / Workflow** – every rule has a *Company* criterion.
## 8. Quick Validation Checklist
☑ Log in as an end user of Company A → only Company A catalog appears, theme is correct.
☑ Submit a ticket → routed to Company A admin group, SLA applied.
☑ Log in as Company B admin → can report only tickets from Company B.
☑ Global IT admins still see everything (no company filter in their admin group).
## 9. Suggested Short-Term Timeline
| Day | Task |
| 1 | Build the matrix, create companies |
| 2 | Attach 10 test users per company, confirm logins |
| 3-4 | Split existing categories, clone to company versions |
| 5 | Design two basic themes, assign to companies |
| 6 | Open routing rule per company, test submission end-to-end |
| 7 | Documentation + internal comms blast (“use this link for your entity”) |
## 10. Good to Know / Limitations
• You cannot host completely separate DB instances in one license; companies share the underlying data model.
• Custom URLs that display *different* home pages (HTML) require a paid “multi-portal” professional service project.
• Reports and dashboards respect the Company filter out-of-the-box—use it!
• Future integrations (Azure, HRIS) should include a company attribute so that new users fall into the right bucket automatically.
## Final Tips
• Configure one change in a sandbox first (SysAid Sandbox or non-production account).
• Keep at least one “Global Admin” user who belongs to *no* company, for emergencies.
• Update onboarding/offboarding procedures to set the user’s company; that one field is the key to your entire multi-tenant design.
You now have a fully segmented SysAid environment without losing the efficiency of a single backend. Enjoy the cleaner experience for both your end users and your IT staff!
![ ](https://i.imgur.com/OE7VHv7.png)
  • June 18, 2025
I can't find how to enable this section.Go to: Settings ➜ CustomizeThen click on: Account Defaults✅ Within Account Defaults:Once logged in, look for the option called:"Use Entities"Check this box ✅Save changesLog out and log back in so the "Entities" menu appears.My license is: Enterprise Edition - On Promise
