Automatically create 2nd ticket
  • July 13, 2023
  • 6 replies
  • 201 views
Is it possible to create a secondary ticket depending the answer from a list that a user selects when raising a request?
Best answer by alin.lupascu
Hi @aaronj
We can use the workflow here to achieve this - keep in mind that the workflows are not available for Incidents however we can do Request, Changes or Problems.
The key is to use Workflow Notifications: That you attach to an Action Item that is conditioned by the user selection.
If you can approach your Account Manager - I’d be happy to assist you with this. If not, you can write down how you’d like this to work and I can do a mock-up.
  • July 13, 2023
I will need some more details about the process that you would like to implement. For the moment you can submit an incident and after this you can submit a new one. If you want to submit 2 incident in the same time, but one of them to depend of the answer from a list, this is not possible for the moment.
alin.lupascu
  • July 14, 2023
Hi @aaronj
  • July 17, 2023
Think you have already answered this with the second part of your response but was hoping to raise a second request depending on the users initial answers from a list.
  • July 17, 2023
Hi @aaronj
Hi Alin
The base is to automatically create a secondary request based on an answer the user gives in one of the list fields (a simple yes or no answer box). If possible to mock up, then that would be greatly appreciated.
alin.lupascu
Hi @aaronj,
I’ve created a short video guide on how to create a new Service Record using the workflows. You can access the video:
https://sysaid.zoom.us/rec/share/QmI732ADg5zQSFE4Koyqm2WMkoLFIeqrbS1qE-GOal5rWeHTtz3QNLcoOBRCdle-.5t-hK7xmAF94TMUN?startTime=1689692577000
Passcode: @M1t$aBP
Do let me know if you have any questions.
  • July 19, 2023
hey @aaronj
If your question is solved, please, mark the best answer🌺
That will help over SysMates navigate better.
