Escalation Rules
  • January 6, 2022
  • 94 views
Super SysMate
Forum|alt.badge.img+3
Hello SysAid I have a problem in my escalation rules! None of my many rules still work after the update to version 21.4.44 b88! I saw that there is a new field "fashion" and I think it has to do with that. Here is an example of one of my rules: Escalates service data records with status Active, Weight = 0 Is triggered 0 hours 1 minutes before DueTime. Set the following fields: Weight = 1 What do I have to do to make it work again? cheers Karlson
Hi Karlson, Thanks for sharing this! Our dev team is looking into this now. Please don't hesitate to share more feedback, Cheers, Maayan
Super SysMate
  • Super SysMate
  • January 14, 2022
This is not a bug in this version! The problem was on my side. My time ranges in the settings were adjusted. I reset them, and then the Escalations Rules worked properly again. Best Karlson Thanks to Keny
