I need the $ code to Process Manager
  • February 6, 2024
  • 67 views
Currently in our Workflow notification we have $LinkToSubTab to work with Assigned To, but I need the dolar $ code to Process Manager.
Best answer by AlexanderChr
Hi @eluiz
There are a lot of tags that can be used in a workflow notification.
The one that you’re looking for is - $ProcessManager
You can find the list of tags here.
Hope this helps you.
AlexanderChr
  • February 6, 2024
Hi @eluiz
  • February 8, 2024
Hi @eluiz
Thanks Amazing 💗🎉
