Powershell - Execute Script (Launch Automation Process) failing every time?
  • July 13, 2022
  • 148 views
I’ve been able to (somewhat) get the Launch Automation Process to work for calling a Powershell script, but I’m having trouble with the script always reporting as Failed. At first I wondered if I needed to use an exit code, but even that isn’t seemingly working. How do you need to end a Powershell script to get Sysaid to report a success instead of a failure?
Powershell script is currently (not sure how to terminate it)
$loc = "C:\AutomateJoe\Powershell\output.txt"
Add-Content $loc "This is 1:"
Add-Content $loc $in_param_01
$process_exit_code = 0
exit 0
Logs attached.
Hi @kyle.bgcdsb
Reach out to our Customer Care so they can review what you have configured and get you sorted.
By Live chat or open a ticket on our Customer Portal
Let us know how it went!
Hi @kyle.bgcdsb
