Routing Rule Creating Complications
  • April 24, 2023
  • 70 views
Hey,
On our sysaid database, there is a rule (?) that is looking at the subject or body of an email and if it contains a ticket number (a ‘#’ followed by any set of numbers) it is attaching it to a ticket.
My goal is to replace this rule with one that only looks at the subject line of an email.
I looked in Email Rules and was unable to find the rule.
Our web account is under help.paccoast.com
Contact info:
Potato Schroeter
Potato.Schroeter@PCCI.Com
916-631-6013
Best answer by jsidoti
look in settings
Integration
Email
Incoming Email
Good Luck
jsidoti
Guru
  • Guru
  • April 24, 2023
look in settings
Integration
Email
Incoming Email
Good Luck
