Routing Rules List not working properly
  • February 21, 2023
  • 8 replies
  • 180 views
Hi everybody :)
We / I have a question regarding “Routing Rules List”. The issue here is, that if someone submits an incident directly on Self Service Portal, it routes it as it should, but it doesn’t route incidents, that are submitted via email. This worked all along till some point and it stoped working completely.
Does anyone have any ideas, is there some checkmark that got disabled/enabled by accedent? Can I view some logs, how specific incident is handled when it comes to Helpdesk, so I can see where it goes wrong?
Thank you all for help and regards
Matic
jsidoti
Guru
  • Guru
  • February 21, 2023
Matic,
Is the email rule enabled?
Is email coming in an a ticket being created at all?
  • February 21, 2023
Matic,
Hi John,
thank you for the reply. Yes, they are all enabled, yet none of them work (8). Tickets get created normaly, they just get assigned to the default group Helpdesk, and not to the coresponding one, that should be asigned.
Regards
jsidoti
Guru
  • Guru
  • February 21, 2023
I have a single email rule but several routing rules with a specific execution order with the last being a catch all
My routing criteria is category
it might be helpful if you could post a couple of screenshots so we can see if anything jumps out
  • February 22, 2023
Hi, this is how the rules look and I opened specific MORA rule.
I crossed over some data, due to privacy policy of users.
Here are 2 screenshots. One is of all the rules we had (this has already worked before, it just stopped working on random day, it is possible that someone checked/unchecked something). Second one is sceenshot of MORA rules, which also doesn’t work.
Thank you and regards
  • February 22, 2023
I have created a completely new rule, new company, new admin group, assigned myselft to it, but same. If I submit incident through Self-service portal, it works, email rule doesn’t work.
Thank you
  • February 22, 2023
Hi, I just figured that when sent from mail, it’s not recognizing companies correctly. So for an example:
It works normaly, if I set for the first rule that all companies emails get rerouted to Test group.
It stops working if insteal of all companies, I choose Test group and I send an email (I am assigned to that company).
It’s like when sending an email, companies are not recognized correctly. If I send an email and I check user in the incident, it’s correctly connected to my LDAP account and I can see info in it, like phone number, name, last name, so it connects my sent mail to LDAP account normally too. Hope this helps some more. Looks like some bug in Sysaid.
Regards
jsidoti
Guru
  • Guru
  • February 22, 2023
as I was looking at the attachments I thought the companies might be the issue.
I’m not sure when company is assigned if a ticket is emailed in. When you do it thru SSP I know it’s picked up at login.
This might be a case for tech support
  • February 23, 2023
Hi, me and collegue are already preparing a Sysaid ticket :) Thank you for your help and cooperation anyways :)
Regards
