Logging into SysAid using Web-services
  • 21 November 2014
  • 191 views
I'm trying to log into SysAid using the web-services framework.
To do this, I'm sending the following SOAP request
<?xml version="1.0" encoding="UTF-8"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
<soapenv:Body>
<ns1:login xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ns1="http://api.ilient.com/">
<accountId>JHUPHA</accountId>
<userName>llee65</userName>
<password>XXXXPLAIN TEXT PASSWORDXXXX</password>
</ns1:login>
</soapenv:Body>
</soapenv:Envelope>
To https://sysaid.jhu.edu:8443/services/SysaidApiService and am receiving the following response:
<S:Envelope xmlns:S="http://schemas.xmlsoap.org/soap/envelope/">
<S:Body>
<ns2:loginResponse xmlns:ns2="http://api.ilient.com/">
<return>0</return>
</ns2:loginResponse>
</S:Body>
</S:Envelope>
It appears that my SOAP request is valid because SysAid is returning a valid response, but the Session ID is always 0. I'm using an Admin account on a University license, but am not sure if some other configuration is required.
Any help would be greatly appreciated. Our ability to connect to SysAid using web-services was a critical part of our decision to purchase SysAid in the first place.
Thanks,
Larry
Did you ever get this resolved? I am having the same issue.
Userlevel 4
Hi josecgomez,
We Higley recommend you move to REST API it is easier to use and is best practice today.
you can read more about it here:
SysAid REST API Guide
josecgomez
Please share Rest API code example for logging to sysaid. I tried python code below but it gives error:
import requests
headers  = {"Content-Type: application/json"}
params = {
 "user_name": "username",
"account_id": "accountid",
"password" : "password"
url = "https://company.sysaidit.com/api/v1/login"
l = requests.post(url,headers=headers,params=params)
print(l.text)
This is error:
AttributeError: 'set' object has no attribute 'items'
Any help is appreciated
Userlevel 4
Badge +4
Hi @abhatia!
You need to create a administrator account in SysAid (or use local admin account) that has permissions and in the body you need to specify the username and the password.
Let me know if it helps!
