REST API Login Help - Python
  • 17 January 2023
  • 6 replies
  • 454 views
I am trying to submit a ticket using Sysaid REST API. I am stuck at making a login connection.
I am using Phyton, here’s the code:
import requests
headers = {"Content-Type":"application/json"}
info={ "user_name": "username",
"account_id": "accountid",
"password" : "password"
#url = "https://systemone.sysaidit.com/api/v1/Login"
l = requests.post(url=url, json=info, headers=headers)
We use SSO/Oauth. I think thats causing problem as I found on Sysaid site that REST Api wont work for OAuth users. Is there a work around?
  • Also, a maximum of two API login requests will be allowed within a five minute period
I have to wait 5 minutes everytime to test , my code. For API development this should not be the limitation. Can you take this off for out company?
Hi @abhatia
Check out this post for how to set up the login process for API:
Regarding the limitation on a number of logins during the 5 minutes unfortunately it is not flexible and was put in place with security standards in mind.
Let us know how it goes and what you are building!
Thanks Maaayan. I created decicated user for API which is excluded from SSO but the url below does not work to login, it just returns the entire page HTML:
[account name].sysaidit.com/Login.jsp?manual=true
I tried it again url below just returns login page HTML:
http://[company].sysaidit.com/Login.jsp?manual=true
Let me know URL for logging to Sysaid via API. I am using a non SSO enabled account
Hi @abhatia, did you figure it out in the end? If not please reach out to our Customer Care team via live chat or open a ticket on our Customer Porta and foind out what is the issue.
Yes I figured it out. Thanks.
@abhatia amazing, would you like to share what was the solution so more can learn from it? :)
