SysAid users are not able to log in
  • November 24, 2023
  • 530 views
Our users are no longer able to log on to SysAid using the domain and user credentials. It keeps on saying incorrect password even when entered correctly.
Below its the screenshot of the setting selected.
dragos.baciu
  • November 24, 2023
Hi @ElizabethM,
Thank you for contacting us, to troubleshoot the issue you can follow the next steps:
  • Confirm that the user accounts are not disabled in SysAid and that LDAP integration is enabled.
  • Check the user accounts in the system to ensure they are active and not locked.
  • Advise the affected users to try logging in using the domain\username format (ex: alpha\usertest).
  • Check if the issue is the same using a different browser or incognito page.
  • November 24, 2023
Hi @dragos.baciu i have tried everything mentioned and it is still not working.
  • November 24, 2023
I’m unsure if this will be helpful, however we had a small group of end users who were having the same issue. We opened a ticket with SysAid and they said the error they saw on their side was: Error: Exception while checking configuration: Communication timeout and then they made a correction on their end. We haven’t had further reports since then, though getting confirmation from our end users has been a bit difficult as it was really only a problem on a couple of systems for them.
