Sticky
Translate Your SysAid to Any Language
  • July 10, 2022
  • 309 views
Hello SysMates!
Welcome to the SysAid Translation Files forum.
SysAid allows you to customize your terminology throughout the platform using a translation file.
In this translation file you can change field names to other languages as well as simply a different term used in your organization.
The default template is located in Settings > Customize > Translation and you can learn more about it in this article.
After you have customized your file to your liking we would love for you to share here with other SysMates so they can enjoy your work as well.
Share the love!
Gracias, Merci, Grazie, Danke, Bedankt, Obrigado, Teşekkürler, Спасибо, شكرًا, Dzięki, Tak,  Děkuji vám, Kiitos, Σ’ ευχαριστώ!, Mahalo, Terima kasih, Mulţumesc, Shurkan, Salamat, Ďakujem, Toda, Diolch and more!
  • June 22, 2025
we like the translations in the classic mode! But in hybrid mode in spaces UI the behavior is a bit inconsistent. Some translations don’t get applied at all. Can you please look into this?
