how do i merge a ticket?
  • September 3, 2025
  • 55 views
Asaf Goldstein
Best answer by SysAid Copilot
## Merge Tickets in SysAid
Follow these steps:
1. Log in to the SysAid admin portal.
2. Go to Service Desk -> Help Desk -> All.
3. Check the boxes next to the tickets you want to merge.
4. Click Merge.
5. Enter a merge reason and choose which fields to keep (right-side panel). Defaults are set at Settings > Service Desk > Merge Service Records.
6. Select the primary ticket at the bottom.
7. Click Merge to confirm.
Notes:
- Merging is irreversible.
- If you don’t see the Merge button, enable the “Merge service records” permission under Tools > Administrators.
  • September 3, 2025
Follow these steps:
4. Click Merge.
Notes:
