Hi @ChiJc ,
To achieve what you’re looking to do, you need to use the attributes section of the action item. This can be done on the template level (request or change template). In the action item, you can select the dependency upon completion of the previous action item. Use the filter to catch the inserted data and use the population section to automatically set up the signee of the action item from the SR supervisor field.
In order to create a notifcation, here’s a link to our documentation.
To edit the attributes, here is the link.
If you have additional questions or need help, feel free to chat with our Support here.
Best wishes,
Erik
HI Erik,
Thank you for your response. I tried your suggestion, and it works. I have another scenario where we have multiple action item tabs and will need to send notifications to specific employee’s based on who is entered on another action item tab, but we do not want to reassign the ticket.
Do you have a suggestion on how we can do that?
Thank you,
Jamie
Glad it worked!
You can send a notification based on the user-populated in the previous action item by create Escalation follow this guide for further instructions.
PS did you catch our workshop about workflow designers during SMART 2022? worth checking out :)
